  • Replies 354
ok I wont have my kit or anything by then so I wont be putting the POS32 in tho I will come down for a look see.
If anyone is interested I do casual work for no wet car cleaning. So if everyone wants their cars done either the night before or possibly on the day I could talk with my boss and get a group clean/discount happening. PM me if you wanna know more about it MissR34.
Cheers,
Nath
yeah id say on the day would be best, driving from Salisbury to southern suburbs means my car will be a pig by the time of arrival.
I agree with damo
come down with us to the show place and you could do the cleaning when we are down there mate
that would actually be the best option
what sort of things can you do minibats??
ur car dosent have to have a kit on it to enter......please enter :P
also wayne, shaz and danai do u three still want to enter??
lemme know asap
do they have females in bikini's doing the cleaning? if not :P no deal
lemme know asap
There is different packages, but I would say it would be tyre clean and outside clean. You can also have the inside done aswell just depending on cost aswell as interest.
I will speak to the boss 2morrow and let him know the date and how many would be interested in a clean and find out what we could do it for. When I was with the SA Rotor club we had it done for a small car sunday and it worked out fine.
cant wait to find out what packages you can come up with Nath
id be just interested in getting my interior done more or less............i dont like anyone touching the outside of my car due to the graphics..........ive had issues in the past where ive had a cut and polish done (this was just before autosalon 07) and the guy that did it left all polish in my stripes that i had on at the time...which then caused parts of them to lift :D
but i use Permaguard anyways and im really happy with that :P
but will depend on price tho :D
and shaz thats ok u should enter anyway..............im sure we can work out someway to mask the damage that was done
i am wondering like how your going to mask my beastadent lol
hide it in the back somewhere
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
