hi all me again asking yet more questions :uh-huh:
in my everlasting triumph to convince my dad to buy a skyline over a new 2003 model crappy car i have come across an effective way to argue my case.
i can argue how RWD is sooo much better than FWD accept before i do that id actually need to know why. basically i know theres better control and traction but is this only at higher speeds? If you could please write basically the facts of the advantages of RWD over FWD id really appreciate that thanks
No flamers unless u have to :D all bumps welcome :bahaha:
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/
  • Replies 47
Bambam's right, FWD is safer to control....in other words...it's harder to get it 'out of control'
definately less prone to spinning out in the wet.
advantages of RWD in the real world? Not much...
That's only if you wanna put your case forward that it corners and handles the way a car should on the race track.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546750
becoz it is a lot more fun
fun=danger
theres better control but not traction
unless u can use yr accleration to turn a corner, let yr tail go out a bit, but can u??
go for 2003 crappy car. u are just a kid, u should learn what a car has to do.:P
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546760
here's something to read about....not sure how relevent it is in your situation.
Article on FWD vs. RWD vs. AWD
http://www.toymods.org.au/fwd_rwd_awd.html
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546780
my first car was fwd, and guyz at work teased me cauz my engine faced the wrong way ! wen i got into my the skyline, its a different feeling altogether, missed the fwd in the beginning but after having a few exciting moments ;-) i wudnt go back. plus engine faces the right way now.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546848
Things worth trying might be: (dunno how true these are, but if he dosn't know cars might be able to pull it off).
- The fact that there is a driveshaft running down the lenght of the car makes it the chassis stronger and more solid in the event of a crash.
- The only reason front wheel drive cars are made, is because their cheaper
- Skyline brakes are generally very strong (not related to drive but might help).
- If you know how to drive properly (which u obviosly do:)), RWD cars can be easier to controll, understeer badly in a corner in a fwd car, ur stuffed, oversteer can be controlled to an extent.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546868
Drive any car stupidly and you can get into trouble. FWD is definitely a safer drivetrain. RWD is more fun, but basically I think you should follow everyone's advice, stop trying to bullshit your old man and buy a car you want with your own money.
If your old man wants a boring, reliable, economical, cheap to insure FWD car then try and bend him a bit but a skyline would be totally inappropriate for his needs.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546873
RWD : Weight distribution is more balanced than FWD. Braking performance is enhanced. Your tires will wear more evenly.
Cornering is easyer and more responsive. Hard acceleration performance is better than a FWD.
Cornering is better due to power and steering is aplied through separate axles instead of the one. There is no torque steer.
FWD : traction is good during mild acceleration on wet/slippery surfaces. Lighter than a RWD. Better fuel economy. Most FWDs have a small engine. Interior room is enhanced because of no longitudinal driveshaft. Cheaper to afford
If your still after that r34 ive left a link in the other r34 post.
Hope i could help
Skyline boy
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546883
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
