Im chasing a r32 gtr with a blown engine/in need of repairs or a rolling shell for a project car.
Dont mind what colour or if it needs a respray.
Would like it to have a pretty straight body with no rust or damage. I hate rust and bog with a passion.
Would rather it be all there interior wise but again not totally important.
Prefer it to be in queensland.
Price wise let me know what you have and post pics etc and we can go from there.
Must be able to be registered.
https://www.sau.com.au/forums/topic/257891-wtb-r32-gtr/
  • 4 weeks later...
  • 1 month later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
