Hi All,
I'm selling off my turbo setup from my rb25 as it didn't suit the auto's drive style.. Went with a smaller HKS Turbo..
Turbo Kit's like new, whole lot is easily less then 1,000km old - Turbo now has a modifyed bellmount so that it plumbs upto stock R33 Turbo pipe.. (Can be returned back to 4" if required with lathe work)
The Kit will include all of the following;
1) Garrett GT2876R .86 Rear Housing
2) Low Mount Stainless Steel Manifold Modded To Suit The T25 Flange
3) Custom 3" Front / Dump Pipe In One To Suit This Turbo on a R33 - (Has Been Glass Blasted & Coated In 1000deg Spray Paint Recently To Avoid Any Rust Forming On Pipe)
4) All Braided Lines & Fittings (Oil Line Possibly Not Included ~ Will Need To Check Tomorrow)
Pretty much everything you need to bolt this straight onto your rb25 for a good increase in power with associated mods, the only thing it doesn't come with is gaskets (might have old ones if wanted), however these can be picked up from Nissan, Performance Shops or event eBay.
Turbo Kit is located in Albury. Happy To Post At Buyers Expense..
The turbo is in perfect condition with no shaft play. Like I said it's done Less Than 1,000Km's.
Looking For $1,100 plus any freight.
If i missed anything or you have any question let me know via pm or just reply and I'll get back to right away..
Best Regards,
Adrian
P.S. Will Try To Post Pics Tomorrow Morning
https://www.sau.com.au/forums/topic/257945-rb25-complete-bolt-up-turbo-kit/
Hi All,
As promised, here are the pics of the turbo kit, manifold & front/dump pipe..
Very sorry for the large files, can't work out how to make them smaller?
Cheers,
Adrian
interested in the kit, although im just wondering why the bell mouth of the turbo was modified? , wouldn't you lose power? and how much would it cost to be changed back to 4"
"Turbo now has a modifyed bellmount so that it plumbs upto stock R33 Turbo pipe.. (Can be returned back to 4" if required with lathe work)"
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
