Item: 1989 Nissan skyline 2 door
Website: this one
Item Condition: Bad points are: has hail damage on roof and boot (quoted $600 to repair) Fibreglass bonnet needs replacing, 2 front tyres need replacing soon due to wheel alignment out (all good now tho) Also the standard RB20 Gearbox is starting to get noisy! But still works fine
Reason for Selling: want a change, if i dont sell it ill finish it off!!
Price and Payment Conditions: Really just seeing who is interested, but for a price say $14500, willing to negotiate with serious buyer, or swap for R32 GTR with damaged engine and cash my way!!
Extra Info: RB25DET engine conversion done a month ago, wiring loom done professionally( all wipers/washers and AC works!!) Wolf 3D version 4 ecu, Garrett GT35R 0.82 exh housing, mounted on high mount stainless manifold. 38mm external gate with screamer, custom plenum chamber with XF throttle body. Custom 2.5inch stainless intercooler piping, 600x300x100mm front mount intercooler, custom 3 inch stainless dump/front pipe. 80mm cat back blitz NUR spec R exhaust, 4 inch intake with K&N pod. made 250kw at the wheels (or 331hp) on only 11 psi, 40 degree day at 30% humidity, made 240hp atw on only 6psi!!!. (i have the dyno sheets if anyone is interested), all it needs is a bigger fuel pump and injectors and will get close to 300kw!! Exedy 5 puck sprung center button clutch.
Has a GTR front bar,car is painted in a custom deep purple. has 19 inch starkorp Kaotiks in black with chrome lip, M spec brakes all round. Tinted windows.
Inside it has R32 GTR seats, nismo gear knob, HKS boost and oil pressure guages. Genuine nismo floor mat set!!
Pictures:
Contact Details: pm me here or call sms on 0406143946
https://www.sau.com.au/forums/topic/258093-fs-r32-gts-t/
yeah mate ill get some pics of the dents for ya asap.. and yes that is a small crack in the bar, spoke to my painter mate and said it can be easily re fibreglassed. bloody lady drivers in carparks!! And remember the price is neg!!
https://www.sau.com.au/forums/topic/258093-fs-r32-gts-t/#findComment-4439367
here are some better pics of the dents on the roof.. the large ones at the back are from the bonnett fliping up on the old owner!! they can be easily pushed out by hand. the other ones are from one of the hailstorms that syd had a while back. spoken to a couple of dent removal places and the quotes range from $600-$800 for the lot. Ill get some more recent pics of the entire car soon...
https://www.sau.com.au/forums/topic/258093-fs-r32-gts-t/#findComment-4439387
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
