Ok its not a RB, its an SR, however same shit still applies and i know there are some smart cookies on this forum.
So i have a NA s14 SR converted to DET. the turbo of choice is a PE1420 on stock manifold and various other things. Have s15 injectors, power fc and a host of other support systems for it all.
ran it up on the dyno and straight away its overboosting to 15 psi. wouldnt be a problem normally but being a NA motor and high compression,l it was starting to ping on the dyno. so timing was backed off until it was ok. We assumed it was the actuator being a 1 bar item. Disconnected it and did a dyno run with the gate flap held open all the way, and it still boosts to 15 psi at top end.
so... theres a problem.
was going to take the turbo off and die grind the wastegate hole larger, however on closer inspection there doesnt look like enough material left to do this and still have the flap closed and sealing it.
am thinking that it may be the dump that is causing the problem here. myself and m exhaust maker have tried a few diff dump designs in the past on my skyline and the split dump usually works really well... gives more power and faster spooling when compared to a normal bell mouth dump.
a split dump was made for my rolla project then, and space was an issue (theres stuff all room between back of turbo and the firewall.) and i think that its not free flowing enough for the gate.
has anyone else had this prob with the PE1420? whats the lowerst boost u can run on one of these? it could be that the turbo itself wont run lower then a bar anyway..... in which case, what should i do?
https://www.sau.com.au/forums/topic/258126-overboost-issues-with-pe1420/
an A/R of 20? this thing must be tiny????
given its listed in twin form for the Z32 it would be a small turbo - are you sure its meant to be used in single application on CA/SR
the Ca's and SR's usually drive pretty good sized turbochagers no problems due to their setup and 4 cylinders
its a possibility
there are a few thinfgs that could make it do what you are seeing - overboosting
crap boost control
poor exhaust
poor actuator setup
wastegate not working
wastegate poor design
turbocharger too small
engine tune mangled
actuator not working
well considering that it boosts to 15 psi with the actuator disconnected and flap held open, that eliminates boost control, wastagate flap, actuator and so on. so all thats left is tune, exhaust and turbo.
at this stage im thinking a bellmouth dump might be the way to go?
with the wastegate held open from the outset, it can do 15psi?
when does it ramp up with it held open vs with the boost controller?
that is pretty unbelievable.. are you sure the poppet is fully open, and not partially
open due to the custom dumps? although an undersized wastegate might overboost
once you reach a certain high boost while closed, it is really hard to imagine such
an undersized exhaust housing overwhelmed with gas yet still able to drive
1 bar on the inlet!
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
