hey guys,
easternats will be running from 10th to 13th of april.
would love to see a big turnout of skylines there, i filled in my entry form, but will send away
closer to the day, never know what could happen until then.
i will be cruising the tracks, drags, and im 50/50 on the burnout comp.
anyone else entering?
regards,
Baset.
https://www.sau.com.au/forums/topic/258153-easternats-2009/
  • Replies 82
I hope the purple R33 that was drifting the front stright last year goes back. :blink: .
would that be [ZILA33], the gtr, if thats the one ur talkin about, no it wont be going back.
got full epa'd and now sits in workshop in pieces, as he thort it be funy idea to try tune it on...
...... 45psi. ARP head studs stretched.
so NO it wont be there. but his other car will. 5.7 ltr VYSS wagon. hopefully on the gigglegas
https://www.sau.com.au/forums/topic/258153-easternats-2009/#findComment-4440047
  • 3 weeks later...
seen and heard that .... its scares the shit out of my wagon lol
https://www.sau.com.au/forums/topic/258153-easternats-2009/#findComment-4483072
That gtr was carzy tuff got a nice vid of him last year entering the track from the pits, crazy 4 wheel smoking take off.. hehehe
will be up there car will not be with me..
link to vid??
just found out his going 26/30.. so next year should be good:)
https://www.sau.com.au/forums/topic/258153-easternats-2009/#findComment-4500286
yea i be going to easternats doing the ride around the track do i have to fill out a form to go on the track or just the drag and burnout comps??? getting my car prep this week end for it new rear suspension going in next week and doing brakes and general service if i have enough cash maybe get a tune as well :)
https://www.sau.com.au/forums/topic/258153-easternats-2009/#findComment-4513203
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
