Hi
I recently bought my 32 GTR and couldn't get it over .5bar
So i cut out the restrictors in the hoses
Then found it had a narrower cat so got a 3in hi flow cat
and ran it with no exhaust to rule out blockage in exhaust
Cleaned the intercooler out and piping
Have cleaned out the bovs
I ran a hose from the waste gate straight to the manifold
Then just changed the turbos with another set of standard GTR turbos and still have the same problem
Was wondering if anyone has had same problem? Has anymore ideas? Or what could be happening?
Im out of ideas
Cheers Jarrod
https://www.sau.com.au/forums/topic/258177-boost-problem/
have you got any boost control? you cant just run a line straight from the waste gate to the manifold cause you will only run waste gate pressure.
Just the stock boost controller that is to the left of the engine bay when you look from front on. Have also tried a GFB Atomic Boost controller. Have also disconnected the lines to the wastegates which "should have" boosted to 1.8bar and blown turbos...... but no.. still runs at 0.5bar
https://www.sau.com.au/forums/topic/258177-boost-problem/#findComment-4441607
How are the actuators on the turbos ? checked those ?
They are fine, the second set of turbos came with actuators as well and still the same problem...
both the turbos and actuators have been changed....
https://www.sau.com.au/forums/topic/258177-boost-problem/#findComment-4441628
The cam belt has been changed and my flatmate is suggesting that who ever changed the belt may have put it on the wrong tooth on the exhaust cam.... which could lead to the exhaust valves closing too early....
Thats all he could think of, what do you guys think?
https://www.sau.com.au/forums/topic/258177-boost-problem/#findComment-4441675
they would have to close late to bleed of the boost, think you are going to need to get it onto a dyno, watch the wate gate actuators to see when they are opening, see how boost is being made and check timing. its a strange one!
https://www.sau.com.au/forums/topic/258177-boost-problem/#findComment-4441707
if base timing is wrong the engine will be sluggish, poor performance and probably wont make much boost
check with a timing light, should be 15deg base timing at idle, if the belt was fitted wrong, this would be a likely explanation
https://www.sau.com.au/forums/topic/258177-boost-problem/#findComment-4441718
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
