Time to clear out some of the parts taking up space...All parts are out of a 1998 GTS-T
R33 stock injectors, perfect working order - $150 - SOLD
Pink label AFM, perfect working order - $150ono
http://img.photobucket.com/albums/v218/madwob/IMG_5215.jpg
http://img.photobucket.com/albums/v218/madwob/IMG_5216.jpg
Bosch 040, perfect working order - removed due to upgrade - $100 - SOLD
R33 window switch $100
http://smg.photobucket.com/albums/v218/mad...nt=IMG_5192.jpg
http://img.photobucket.com/albums/v218/madwob/IMG_5193.jpg
R33 stock front and rear sway bars - $50 each pick up only
http://img.photobucket.com/albums/v218/madwob/IMG_2142.jpg
R33 smic - $30
PM or post in the thread :thumbsup:
Cheers
Dezz
https://www.sau.com.au/forums/topic/258255-r33-gts-t-stock-parts/
  • 4 weeks later...
  • 3 weeks later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
