rips,
i see. so having the girdle braced to the shithouse lets it rev more easily? please.. i know it will make it more reliable or what i think is good insurance..
if an engine crank moves around that much evan though its fully balanced?
not having a stab, but i think some peole may be mislead into believing there is no way a rb30 can do 9k without said girdle.. i mean there is nothing wrong with the cast iron stocker.
and regarding the oil pump issue, perhaps i have seen to many rev limmiter dammaged pumps that have swayed me into thinking they will fail. or if not but when.
i take it you have a race only balancer setup and a very soft (good) rev limiter?
  • Replies 165
Shanef, (with tounge in cheek) I'm so glad you know all about my products, what they can do and what they can't what they include and what they dont and what works with what and what doesn't, saves me alot of time, incredible :D (couldn't find sarcastic face, lol)
IMO the sump bolts play a key part in holding the whole deal together, you wouldn't be happy to let the sealer dry then pull out the bolts would you?
If you can spread load in any direction and minimise it at any point it has to be an advantage and the sump bolts are definatly to be counted as an integral part of the bottom end.
Rob
Sorry rob while u were busy working i was just sitting on my bum on the computer as only a good aussie does so i thought i'd reply on your behalf.
Pass that sarcastic face please :)
Re the sealer drying 'issue', i'm half looking into getting gaskets cut to make that process alot easier. Then thatd also give a consistant thickness so it wouldnt affect the clearances with the aftermarket girdles. Have u thought about doing something like that too?
I'll put that idea into the adapter plate thread so it can be discussed there too
rips
how long does it take you to assemble one of these bottom ends?
hows availability? how would i contact you buddy as im quite serious about a rb30 in my hopefully new r34 gtr.
my current r34 gtt is just to much wheelspin with the rb30 =[
Edited by VB-
  • 10 months later...
Ill take some shots this weekend...ok
australians build some of the best gearboxes in the world...why is it so hard to believe they cannot do it with transmissions Robbie?
These guys engineer some of australia's best street and show cars so i don't at all question what they have achieved. Mick Stanic from Subzero also has done a T400 GTR box although ive not seen that one 1st hand.
Whatever happen o the picture?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
