4 x Standard R33 GTst Wheels
Great condition with 4 x Kuhmo's 205/55 R16 80% tread left
$300ono (pictures soon)
4 x Standard R32 GTst Wheels
Great Condition with tyres treads are about 30-50% left
$200ono (pictures soon)
Set of R33 GTst Front and Rear Discs and Pads
Plenty of meat left in both sets of discs
Pads: Fronts 70% Rears 60%
$160ono (pictures soon)
Set of R32 GTst Standard Coilovers
Comes With set of Kingssprings superlows and Standard Springs
No Leaks, Working Perfectly...
Still on car atm new coilovers going in weekend
$240ono (picture of car height below, pictures of coilovers soon)
Rare JDM Greddy Type S Blow off valve
Black Top, great for the stealth look.
$230ono (pictures below)
Blow off valve not sure of brand
Good condition, vent to atmo only big trumpet style very loud.
$125ono (pictures below)
R32 GTst factory stock mount intercooler kit
all pipes etc...
Good for compliance make an offer
e.g. $80ono (pictures soon)
More bits and pieces to come...
All items available for pick up in South West Sydney Area
Offers welcome, Low ballers aren't...
Cheers Tim.
Edited by krayzie32
Pump p p pump pump p p p pump
Pump p p pump pump it up!!!
Pump p p pump pump p pump p pump
All pms replied!!!
  • 1 month later...
UPDATE: PRICE DROP
All PMs Replied to
Car Dramas causing me to sell stuff off to cover repair costs!!!!
$300ono $260 (pictures soon)
$200ono $160 (pictures soon)
$160ono $110 (pictures soon)
$240ono $200(picture of car height below, pictures of coilovers soon)
$230ono SOLD (pictures below)
$125ono $85 (pictures below)
all pipes etc...
e.g. $80ono SOLD (pictures soon)
Cheers Tim.
New items
2x 16x8 R32GTR Rims w/Pirelli Tyres NEW
$500ono. pic in 1st post
2x 17x9.5 +17 Rare Panasport G7 w/Falken Azenis 30-40% Tread
Edited by krayzie32
  • 3 weeks later...
hey mate would u sell the 205 55 r16 tyres off the r33 rims as im chasing just the tyres. if so how much? thanks
Wheels come free with tyres for that price not worth separating. Sorry.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
