i took my wing off but now i am putting it back on and while i was tightening the nut the bolt snapped in half. how can i fix this? is there anyone that knows how to put a new bolt into its place? do i have to take it somewhere special?
https://www.sau.com.au/forums/topic/258358-snapped-bolt-in-wing/
take it to a professional, you're hurting your car too much doing DIY's
ie. brakes and now the wing, just go to a pro and ask for advice... they may quote a high price but it doesn't mean you have to carry on with the work there... just find out how to fix it then gather a few mates as we've done and do it at home ONCE you know how to fix it
do it asap as well as the boot will shortly rust, especially in this weather... if you're thinking about getting a kit later, just weld and paint the boot anyway because you'll do it later, my advice Sunny, you know it's up to you whether you take it or not
Edited by hoony
  • 4 weeks later...
try a smash repair ... ive done mine there before because the wing i bought didnt have a screw on it .. it broke off already, they
remoulded it with a screw in there. Dont think ur gonna care about the price since u want it back on so badly ... LOL ... im just
kidding, wont cost u much anyways ... i got mine done with this guy called 'CK Lee' in Wealshpool ... 0418 913 608 ... call him and
enquire ... he's not the best but he's not that expensive either ... hope u get it back on ... oh btw its not God who doesnt want
spoilers on skylines .. its the devil himself !! RAWR .. so quickly get it back on .. hehe :devil:
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
