hello all
i need a favour from someone that has a stock intercooler,stock exhaust and stock air intake cause i need to turn my car to stock due to the DECC if anyone could help me out it would be very much appreciated i'm located in smithfield if you can help me please do not hesitate to PM me or email me my email address is [email protected]
thank you for your time,
https://www.sau.com.au/forums/topic/258392-need-help-from-fellow-sau-mates/
hello all
there will be a reward for your time and kindness!
  • 4 weeks later...
http://www.climatechange.gov.au/
what a waste of our tax $$$$$
industry produces most of our C02 here in Australia and here they are stuffing around with a car with an exhaust, intercooler ect....
what a joke....
We should propose to plant a tree for every modded skyline on the road to offset the "so called" extra C02 produced by our very sexy very quick petrol guzzling skylines..... and leave us with our exhausts, filters and coolers....
what a joke....
yeah bro it's a bloody joke anyways can anyone here help a brother out i've got another week to get it cleared
thank you in advance.
hello all
i got a stock airbox or a r33 gtst if want to buy it off me. i dont need it anymore because i dont have a skyline.
PM me if u want
hey man.. i got a r34 stock muffler if you want
thanks for your offer bro but i,ve just picked up a stock exhaust now i really need a stock air box and smic to borrow or to buy if you can can you keep a lookout for me that will be very much appreciated my number is 0431401777
thanks again,
i got a stock smic just no piping for it cuz im still using the turbo side of the piping for my fmic and the other pipes have walked away and hidden somewhere lolz can have the cooler for $50 if ya want..... im in wetherill park as well so not very far from u... i sent u a text earlier this arvo
hey bro sorry i got your msg last night anyways i need the piping too with the smic but thanks anyways,
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
