FRIDAY 3rd October
JAKESY wrote...
We doing a coast cruise people. Starting at 101, and heading to the redlands and then going the back way onto the M1. Going to be long driving routes and as usual; expect nothing less then 60 cars. We will be making a brief stop at Yatala BP at around 10:45 - 11.00 (there abouts), this is so you coast people have no excuses . Bring CB's as usual
For All those interested u can find out more (and directions) at
http://www.boostcruising.com/forums/index....opic=17024&st=0
Times
BP COOMERA (Gold Coast Meetting)
6:45pm --> leaving when ever1 is ready
101 MOTORCAFE
7:30pm --> 8:50pm (leaving at 9)
REDLANDS DEST.
9:30pm --> 10:00pm (leaving at 10:15)
YATALA BP
10:45pm --> 11.00pm
BWCP
11:30pm round-a-bout
https://www.sau.com.au/forums/topic/25845-friday-coast-cruise-31003/
MotoX, 101 is a new shop in springwood
http://www.boostcruising.com/forums...opic=17024&st=0
(theres direction there...)
i haven't been there yet but im pretty sure its a performance shop. my name is Robin, by the way ill be driving the skyline u can c to your left...
mmmm wayne aint comin in my car it looks, no matter i may have a passenger anyway, otherwise im cruising on my own :P
yay me
godraver ive seen ur car around a few times, the gold grill is rather eye catching, looks good tho :P usually tho we are in the crv when we see ya!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
