  • Replies 44
I bought a cheepy, $350 ,that had a few problems with it (compressor wheel was eroded and exhaust housing was badly cracked) took it to per4manz turbos and cost about $600 to fit new compressor wheel and machine out second hand stock exhaust housing and new seals. bought some gaskets and fitted it myself , a easy job if everything comes apart ok. a bit more laggy than the stock one but heaps more pull when it gets going. went from 290rwhp at 12psi to 307rwhp at 11psi. aiming for about 350-360 at 17psi when injectors and ecu are fitted.
Edited by Pal
soo pal do you think that if i go with the $350 i will hav problems with ...
thanks for all the info its really good ..
if any1 has got a hi-flow for sale let me now ..... and if you hav got a r33 with same mods as me let me no power adn how much ti costs ..
thanks guys this forum is really good :)0
if you dont know the history of the turbo it's worth the extra coin to get it checked out before you buy it, and rebuilt if needed(making sure it is worth it first). not worth sticking it in and it popping on you. i put mine in just for seals and machining which was around 300 bux but due to the compressor wheel being stuffed, that put another $300 on it.
soo ppl is there any1 out there with a r33 that has a hi-flo .. wat boost are you on adn wat mods do you hav ...
on my car i hav a turbo back zorst , pod , cooler , fuel pump, and will be installing safc soon ... if i get a hi-flo turbo wat boost do you think will be safe for my car and would any1 know wat sort of hp ill be getting ..
thanks guys evry1 has helpd alot ...
230-240rwkw @ 16-18psi.
It's not so much "safe" boost levels as opposed to having a "safe" tune which will keep your engine alive.
Best (and safest) gains will be had with a proper ECU though. Probably going to max your airflow meter and not sure how an SAFC will go tuning past the AFM limits..
may get a bit more depending on turbo, i got 229rwkw at 11 psi with a safc2, hoping for 260 rwkw at 16-17 psi with injectors and full ecu
Edited by Pal
Yours must be a similar size to the hiflow on my stag then, 240awkw @ 12psi seems to be a bit more than normal 33 hiflows (mine is a hiflowed neo turbo so bigger exhaust housing). Some new injectors and ~18psi I'd hope to see ~280awkw.
mm not soo bad :) .... cant wait to get my car back on the road ...
duz any1 also know how much it costs to get the safc installed and tuned ...
i got safc1 is that crap or would itn help me a lil ....
and has any1 got a hi-flo for sale for a r33
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
