hey guys i am trying to do a cv joint replacement on my car and i have run in to a small prob i can not get the spindle nut off from the cv join...... i have tryed a number of things e.g heat then rapid cooling, a prybar with a steel bar... i have released the safty mek on it but it still wont come off... i dont think it has ever been changed...post-45923-1235483537_thumb.jpg
https://www.sau.com.au/forums/topic/258530-need-help/
You will probly need to shock it. If you cant get hold of a rattle gun, put a socket and breaker bar on it, get someone to put weight on it and tap the prybar with a 5lbs Lump hammer. Not much else you can do.
Or, drive the car to a workshop, get them to rattle it loose, then just tighten it up to drive home. Piece of cake.
https://www.sau.com.au/forums/topic/258530-need-help/#findComment-4444443
Just did this, this arvo on my charade turbo.
Fit the wheels, and make sure the center cap is off and car is on the ground, in gear and handbrake on.
Put breaker bar on and use a three meter long pole on the bar if you don't have a rattle gun.
Both came off easy :down:
https://www.sau.com.au/forums/topic/258530-need-help/#findComment-4445884
Both came off easy :)
:P YEA GOT IT :):blink: me and a mate had to put all our weight on it.... it had welded on there... but yea all good now thanks for the help :blink::D:/
https://www.sau.com.au/forums/topic/258530-need-help/#findComment-4446225
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
