  • Replies 285
new motor, new turbo setup more power but u run slower than ur old times...didnt u give adrian shit for something like that? :sweat:
P.S sounds good pauly :PBJ:
not a new engine...just freshened.
it didn't run as quick but it did run faster.
yes it sounds good but due to a plumbed back wastegate its not a 'off tap' as it could be.
Edited by DiRTgarage
Yeah saw that, but the RB30 8 sec pass is enough for now. Once Paul catches up we can post that vid :D
RB30 > RB26
i see your 7 sec pass...and raise you a Godzilla Motorsport 7.84 @ 184
RB26 > RB30
i did notice the distinct lack of gate barrrp
are you trying to trick everyone into thinking you still got lowmounts?
it has been said the wastegate plumbed back helps scavenge gas from the turbine. In theory it sounds right but back to back testing is the only way to be sure. I have another HKS wastegate flange...i might knock up a screamer and do a mythbuster's on it.
Soooo...what is Mark up to? I didn't get a chance to speak to him about his car...
And... when are you back out? Have you order a chute? :P
You should have been rude enough to ask him.
next friday night...see
http://www.wsid.com.au/includes/Wicked/entrylist.pdf
no chute...i got away with not being logged on both my 140+ runs.
nice...best of luck for next Friday.
Oh, and I noticed the irony of your ANDRA race number.... :P
Back on topic...Anthony Maatouk is up there with the best RB30's in the world: 8.1@171MPH all on a 10.5" tyre. Even batter is the fact that the car has laid down 1080rwhp with a single cam.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
