  • Replies 881
I would but noones ever there when I turn up. Hazards of living at Goolwa. I went last week didn't get there till bout 8ish though.. didn't see one 'line in the park. Still got a couple of pies... cant resist
Generally what time are people there till?
I think i saw you driving south on west tce last friday night when we were going to bp.
Hopefully not when I had my momentary lapse of consentration and slid into the middle of the intersection at a red light on west terrace. I was looking at the next set of lights. Looked like a right c*ck, ABS going mental. I just must have missed you all by minutes.
BTW Congrats on the Stag purchase.. what a beast.
Edited by Stagstock
just wait til you hit a 4 week stint. its awesome. :blink:
i dont think the celsior was off the road over the year that i owned it for as long as the 200 has been in the last 2 months.
Edited by scandyflick
see well the celly still had the toyota reputation
always reliable.
now it just looks like shit especially with its veranda rear guards
it must be a nissan thing.
i think it must be u guys p ing in the fuel tank or something :(
my immediate family had about 10nissans over the last 20years all for lengthy periods and never really had probs with em. the only pieces of crap that regularly broke down was my bros escort, my mums crappy vp and my bros stupidly moddified swift
Paul and i are wishing we left the gearbox to another weekend.....got the box in...only to find someone had completely stripped out the filler plug.....tried hammer and chisel...hammer and punch....hammer and bolts....lots of swearing...we even drilled it our to put and easy out in....got an oxy set..heated the area up..and snapped the easy out.....had to take the back of the box off and change it with the other one we just took out :( ....dammed pulsars..wouldve been perfect cruising weather too.....oh wells.....next week i-we may make an appearance
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
