  • Replies 881
the cure for the rick roll is wait til the browser stops moving, then close the tab, hold down enter until it runs through the lyrics, then the tab will close.
hahaha love Firefox.........do what Damo said and firefox will ask you "Do you want to navigate away from this page".....all you gota do is say f**k YES and Rick is gone
I plan to be there ... but I am selling a house and have a few more items to do around the property. Open inspection is the following day, so I don't have much time. I'm getting a few jobs done after work tonight, so I'll know by tonight if I'll be in attendance.
Might also take part of the day off tomorrow ... just to put the missus's mind at rest that all wil be done and dusted.
Ruby, I rolled up to BP last Friday night to give you my club membership form but there was only a blue Stagea and a R32 there... both of which I didn't recognise from on these forums.
Ah, sorry mate. I was stuck with the 10yo lad. Got out to Vilis for a bit, but he was tired and grumpy by the time we left Vilis. I'll be out this Friday night at the BP :/
that would be Chad (DSTROY) in the 32 and Lex in the blue stag
if its the same 32 i saw it wasnt chad
Possibly Dion then? Nathan?
Talbo, I'll be out this Friday if you want to get the form to me then :rofl:
can someone bring a membership form for me please???
Sure will :D
Edited by RubyRS4
Talbo, I'll be out this Friday if you want to get the form to me then :D
No problem, I think I should be good to come past tomorrow. :D
It wasn't chad's 32, i've seen his and it obviously has the custom # plate. The blue Stag had a custom plate however.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
