  • Replies 881
lol, that dude come over to where i was with my patrol mates (one of them is a security guard at a few venues around town) and he knows him from vodka bar. apparently he gets a bit angry on occasion
ended up goin via the land of promise (as matt had to do some work down there), then jon and myself lapped town. got to see 50 odd people punching on as we drove past the woolshed haha
umm interesting now...getting kicked out of BP
Ha. I recall a year or two ago, the BP had a security guard who stood out front. Tried to get the bikers to move on. At that time they were trying to enforce a 30 minute maximum parking time. We argued it wasn't acceptable, because we were patrons, and to shoo us on in 30 minutes when we needed time to refuel, eat and drink. And they did not have signage in place to advise of the parking limits anyway.
Their next strategy was to close the public toilets. But that was illegal and we pointed that one out. Facilities must be made available to the patrons during full opening hours.
Must just be a BP thing :P Some dude at the Port Wakefield BP was complaining about Troy's car being parked at a pump ... when he was in the line to pay for fuel. The same dude just minutes later was parked in front of the automatic doors, next to my Stag (parked legally). :P When we left the BP I blew the guy a kiss. :down:
Edited by RubyRS4
So the question is, will you still go there after Vilis? Or is it time for a new venue?
As long as my biker mates still go there, then so shall I. We've been attending BP for over 8 years now and we haven't left yet. Its central, and its convenient ... and provides for good laughs at the wide variety of 'types' that go thru there. :P
BP should at least respect the BLUE MESH.....:P
I will most likely still go to BP what they going to do....as long as we keep buying something from there they cant tell us to move on really
well...if you guys want a run down south..i'll be fitting my turbs,doing my brakes and servicing the trans if ya's wanna do a fly by or even pop in to dribble shit...i'll be surounded by dattos as well...mainly 1600's
4 wagons and 1 sedan in the shed...occupying space with a 1200 sedan and a shitter fairlady...1 sedan outside occupying space wit a shitter exa turbo and a kitted honda which got reversed into....1 wagon is relatively drool worthy...other one is waiting for a s15 sr20 conversion to be finished...others are projects that havent even started...all up at pauls shed
Who is planning on coming to Villis tonight?...cos i am
I should be. I'll have the lad with me, plus I've got some running around to do beforehand ... like getting another bumper for the 33.
Ahh Cam he can tell us more jokes :blink:
or he can tell us more about zombies
as previously stated...i'll be giving my 31 an early 21st birthday pressie tonight up the end of panalatinga road..onkaparinga hills.....hopefully it wont be too cold
have fun with that, that road would have to be one of the smoothest i have seen in the south...actually in all of adelaide.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
