or he can tell us more about zombies
Dear son of rajab, don't get him started!
have fun with that, that road would have to be one of the smoothest i have seen in the south...actually in all of adelaide.
What? A smooth road in Adelaide? You lie!
  • Replies 881
I don't remember any info on Zombies in Kadina .... however I do remember Cam falling into the ocean (well a little part of it anyhow), and also remember him help me smack myself in the face after I had had a few beverages :blink:
Ahh he got you good on the smack on the face andrew.....lol me and anthony we listening to all of his jokes....and i remember seeing the expression on tracy's (rubys gf) face, it was priceless lol
yeah I may or may not have dropped by Villi's to say hi with Munro in his new Gun Metallic R35GTR tonight ....
Sorry for the dodgy blurry pics, but you get the idea! - IPhone camera at night = fail
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
