  • Replies 881
I have this feeling my car is going to end up like Scandy's.
SAU:SA #17
Car(s): R32. Hardparked.
Real Name: Dion
Trader Rating : 1
Need to do Turbo, FMIC, Coilovers, A/C compressor, Seats and Steering Wheel. I know its not that much really but we're talking about me here. Oh and also RB26 Injectors - I believe it already has an upgraded pump, but if not, that too.
i have a case of CC's n dry....very nice taste
So who is going to help me now????
cc dry... you just became my new (temporary) best friend.
<snip>
lol. ill give you both a hand with all that.
yay i has a temp new friend :P
I will go and see andrew at am on friday and get him to make the intake and dump pipe and that way once they are made we can start on it straight away.....roughly how long will it take Dave to slap it all in????
dunno. depends how many cc dry's ive had and how awkward the rb is to work on. should be about a couple days (i like leaving a margin of error). now takes me about 90 minutes to do a turbo on the sr.
question, rb uses locking tabs on the turbo studs, yeah? if so, f**k them off and buy some prevailing torque nuts, theyre a slight pain in the ass, but i doubt they'll f**k out as quick as the lock tabs.
Edited by scandyflick
lol i have no idea what you speak off there Dave.....
lol. find out when we pull your turbo off i spose. but add maybe $10 for half a dozen prevailing torque nuts.
when you wanna do it?
When andrew has finished making the intake and dump pipe....will take the turbo to him on friday
CC is my fav. Basically sleep with the stuff.
However just got nice little connection atm. $80 dollar Cognac bottles for $30. very very nice stuff.
oh, so this thread is talk about villis?
i may be there for a bit, meant to be getting the bitch muddy again, but got a lot on this weekend so dont know if thats wise
save the mudding for saturday, ive got the weekend off and will be in need of cheap luls. :)
Ok my bad >_< I fly in to Adelaide at 10:30pm....Was looking at the wrong details LOL
Doubt you guys will be at villies still that late...
around that time we usually are at BP lol...but since we aint going there no more who knows where we will be
Oh you guys still do that.....
I used to hang at Shell LOL ...That was a longggggggggggg time ago now tho :down:
Well I will be at the public meeting if all else fails! >_<
save the mudding for saturday, ive got the weekend off and will be in need of cheap luls. :rolleyes:
saturday night john is busy, and apparently ive gotta make an appearance at drifts if i want some mudflaps LOL
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
