go the pies richmond did well for three quarters though when they can play four quarters they will be a hassle to beat....did anyone see cousins throw up i was drinking at the time brought back memories made me stop drinking
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448707
Didn't seem to faze him too much. Must be used to having big nights or something :wacko:
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448732
Yeah could be that he was pushed pretty hard, I didn't see the match, did he cop a big hit? I used to see a lot of guys hurl during gradings at Karate.
First quarter he got his head taken out by a tackle. thats all i seen. didnt seem to bad but must of hurt him
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448741
no Rusling, Medhurst, Rocca in our forward looks very promising indeed
I know fingers crossed.
Massive fan of Harry O and Shannon Cox is coming along nicely!
And how good is DIDAK?!?!?! He is cleary Peter Daicos' love child.
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448744
My standouts are Didak, Johnson is coming good. Leon davis brilliant and heath shaw is proving he can play.
Mate alot of potential there we just got to be tight all year and not loose stupid games
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448749
Richmond not with a full squad kept with Collingwood for 3 quarters, who where pretty much at full strength bar 2 players.
Yep Collingwood are going to be great guns this year!
GO CATS!
Richmond where not even close. Not sure if you watched the game but scoreboard didnt do the pies justice. they smashed them all over the ground
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448756
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
