looking for tein coilovers new or 2nd hand =] front and rear or one if em for a hcr or ecr r32
let me know
thanks heaps :)
OR where i may able purchace in sydney new
Ive got a brand new set of Tein super street for an GTS R32 .Was told they would fit my 300zx as well as GTS R32 but they don't.Access Autoworks refused to take them back as they are thieving scumbags.I bought them before the price rise so they owe me $1500 so if your interested that's what you can have them for plus any freight.I'm in Melbourne.
ill consider it gtr ones fit a gtst ? .... pm sent too
Okay mate,the part number of this kit is GSN18-A1SS2.If you go to www.tein.co.uk/price/nissan.html and check the part number you'll see this kit fits
an HCR-32 89-92
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
