hey guys im selling my gold drift techs as new no marks on the wheels 80 to 90% tread left . some one make a decent offer as im changing from drift style to bling . will have to organise own freight or i can organise it at extra charge will fit skylines stageas most nissan and toyota also fits 4 studs like 180s . pm on here or call on 0409454739 cheers bernard
https://www.sau.com.au/forums/topic/259121-17-by-95-genuine-drift-techs-as-new/
Could you possibly find out exactly what the offset and widths are?
What brand/model tyres? What size tyres?
Could you remove a wheel and photo where the offset is stamped?
Would you send to VIC 3168?
the one in the photo is a DURUN 235/45/R17
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
