my mate has smashed his 32 GTR tonight, passenger side banana'd
front guards $600
bonnet (available in 2 weeks) $600
front lights $300
front grille $200
front brakes $300
rear cut incl window, rear cradle, diff $2000
seats front / rear $700
RB26DETT with fresh recod head ($2500), just last week!! withn1 oil pump, loom and ecu $5000
gearbox and clutch $700
bootlid and wing $400
bare front cut with windscreen $1000
all interior parts are for sale, pm with what u want or need ill see how i go. car has started to be stripped, so please be patient and ill do my best to attend to everyones enquiries.
thanks
https://www.sau.com.au/forums/topic/259343-wrecking-r32-gtr-1994-black/
front guards $600
front lights $300
front grille $200
front brakes $300
thanks
im after the console surround that goes from around the gearstick to up around the centre gauges.
I'll take the front & rear seats if they're in good nick, no tears/rips/stains etc.
I also will need some interior trim pieces. PM me your details and I'll give you a buzz.
ill take the whole boot parts, interior plastics in the boot.
ill take the two front kick panels, and the ash tray.
also the two side plastic skyline panels that run on the sills.
ill also take the original airbox if you have it
and the original exauhst if you have it.
please pm me
ok, as soon as we get it off and its all good ill pm u and get ur details
so, this part sold to u pending.
Ill take the full front end bonet,lights,grill,front bar,and both gaurds
pm me your number
pm sent
hey, theyll need a clean but no rips etc in them
pm sent
please pm me
whole boot parts arent there.
u can have the kick panels, ashtray and sill panels. and ill double check on airbox and exhaust, pm me
Ill take dash cluster/o2 sensors from exhaust/Clutch (depending on what it is).
PM me prices,
Thanks
will check 4 u n get back to u
Hi, is the lip that sits under the front bumper available?
Cheers :P
sorry not available seperate. front bar and lip will be available in a week or so
keen on the front bar and set of seats if their in good cond?
pm me
sorry, so far both r accounted for
GUYS, THE CAR IS BEING STRIPPED ATM SHOULD TAKE A FEW DAYS, ONCE ITS ALL DONE, I WILL START TO PM U ALL AND START SENDING THEM OUT!
hey a quick update, most of the interior has now been stripped, seats need a good clean, will start updating with pics tomoro but heres the list of things available now
front guards $600/pair
bonnet $600
front lights $300
front grille $200
front bar no lip $300 (lip available 2 weeks) $300
front brakes (incl. DBA slotted rotors)/rear brakes incl all 4 hubs $800
rear cut with quarter panels $1000
drivers door $250
centre console $50
stereo/shiter surround $75
door trims $100
rear upper trims $75
rear lower trims $75
carpet $50
cluster surround with switches $100
RB26DETT with fresh recod head ($2500), just last week!! withn1 oil pump, loom and ecu $4500
gearbox and clutch $500
bootlid and wing $300
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
