as you all know r34gtt gearboxes have pull type clutches but im finding it hard to get a decent clutch at a decent price good for 300rwkw
now my idea was if i converted my clutch set up to push then my horizon of choices would be broadened correct?
will this kit work to convert or have it got it the wrong way around.
"OS Giken used Push to Pull conversion kit for Skyline gearboxes"
thats what my general consencus on the whole pull/push conversion
just confirming that the os giken push to pull conversion will be the right kit i require and as to whether i can merge the conversion kit with another branded clutch other then a os giken brand.
the topic title and the statement above is ass about.
the OS Giken kit is pull to push conversion.
If your bellhousing has the bosses cast into it for a push you can convert it using the genuine Nissan parts...thats what i did...just drilled and tapped the bosses and bought the required parts to convert it.
Edited by DiRTgarage
hmmmm interesting and was this accomplished on a r34gtt gearbox?
if so what was the total cost of the conversion
I got this from another forum
Clutch Pull to push conversion-
Late Model R32, R33
Front cover assembly :32110-05U11 (japan part only)
Gasket :32112-05U12
Clutch fork :30531-01S00 (same part for a 1991-1993 240SX)
Spring :30514-14600
Spring :30534-E9000
T/O bearing :30502-14601
Bearing sleeve:30501-S0160 / 30501-N1601 (14mm for twin / trip disc)
Bearing sleeve: 30501-K0404 (24mm for single disc)
Dust cover :30542-31610
Slave cylinder :30620-21U01
Flywheel bolt: 12315-04U00
Time for you to call nissan and find out the price fo the parts.
Edit - and here's a thread describing how to do it
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
