nah it all went bad. probably oil pump failed bacause i lost all pressure suddenly but the big end bearing that has spun doesn't sound too bad. hopefully not too much work to fix it....last I heard the motor is already on the floor sounds like brad is pretty motivated so see what happened :down:
I on the other hand intend to celibrate this motor's life by getting shitfaced. It had a brilliant record, 4 wins from 5 starts. It's short life will always be a highlight for me.
Round 3 isn't until 30/may so 6 weeks to sort it....if its not too bad that should be do-able. Any chance of doing OK this season is gone though because I missed 32 points in the enduro this arvo.
  • Replies 156
Posted Images
Hope it's only as bad as Brad thinks it is mate.
Good luck. Don't let it knock you, you did awesome out there today, killed them all, some great driving!
yep his as serious as they come
Its all out and stripped in the garage.
Has wiped 5 and 6 big end bearings only the upper bearings are really damaged but its enough to have a slight knock.
Will have to pull the oil pump apart tommorrow and see whats going on there and perhaps build a better sump for it. First impressions are usually right and it looks to have surged.
The rest of the engine is mint as it should be.
Edited by Risking
On the bright side, the impact on points in the overall championship may not actually that bad (however that statement needs to be qualified by the fact that our calculations are already half pissed and by no means offical!).
We look to be sitting about 15 points off the championship lead (a race win is 16 points) so it could have been much worse.
And hopefully we can get the car together and back on as good for the next round.
No pressure Brad :down:
Actually MASSIVE thanks to Brad for his offer to strip it all down & fix stuff- we really appreciate it.
And as you can see he's already got stuck in - now that's commitment!
I got the text last night about the win again, was stoked to hear!
But after reading now, man thats gotta suck, sorry to hear :(
glad to hear Brad's on the job!
Hope its no big hassle and you guys will be there next round to get more winnnnnaaaar's points :down:
We'll be back well before the next round.
Its bad but not as bad as Duncan's previous attempts to break it.
At least everything is where it belongs and it still goes roundy round realativly smoothly
Big congats to holt and howard for taking out the enduro, would not have been an easy feat with 4 cars on the lead lap.
I also noticed that Jacksons Calibra finally cracked the 1 min 1 second around there with a 1.00.58!!!
That is some serious pace!!!
Edited by Risking
  • 4 weeks later...
oh you are a nasty piece of work. get off the interweb and back to the garage....I need to enter in the next 2 days so I need to know if it will be ready or season over :P
I've got the water lines back at least....let me know which night we are sealing it up. And you owe me bank details still....pm me.
Dave, are you back for the next round? Brad have you entered? anyone else popped up to have a go, I don't know if Mick has found the thread yet but he was in prod sports in an rx7 at EC with scott helping out
engines done buddy, everything is weighed withing a gram of its life, balanced to perfection and assembled.
Sam ended up drilling out the oil returns, the crank I told you about, few other little things to help with oil control. We line bored the main journals too be sure as well.
Iv'e got one piston back out sitting on the bench and eveything laid out for old mate Mike Hanley to come seal it up. Regardless of the cams being back or not im sealing it up wednesday night. Mike can come back with the cams once the engine is in for all I care. He can seal the sump and head then seal the covers latter.
Once the head is on I can do the turbo's and external oil pick up crap without the cams. It will be going in next saturday and you will have it back by tuesday ready to race.
Im very impressed with the oil pump, its a really nice unit. And wait till you see the sump in person. You bash it against a ripple strip and im coming after you!
Im not aloud to drive for a while (doctors orders) so I have not ended up entering this round. Jay is going to take it out to the SAU oran park day.
The car is back here now so you can suss it all out when you come down during the week. Its getting some suspension surgery over the next two weeks.
Edited by Risking
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
