r32 gtr 1993 model shell ..
basically interior complete missing front seats the rest of the interior is there..
needs engine, radiator cooler and so on ..gearbox tailshaft and back from there is still in car.
still has brakes and rest of drive train..
Engine bay has been seem welded and and painted black..
basically selling car as i just purchased house today and selling to help free up funds...regretably
$5500 location brisbane..call 0422745620
nismo 1.5 way lsd suit r32 gtr no housing just diff $600
ganadors suit r32 gtr gtst $350
can freight
can freight
got any pics of your house ?
can freight
1500 CASH MATE
Could you please send through the vin/chassis number.
What was the reason for seem welding, front end clip?
:P
the reason for seem welding is the car was going to be used for road/track..as for vin call 0422745620
thanks
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
