This thread was made for me! You can't keep it to wagons though, if you are looking for inspiration I would look at everything for style, content and application. Have a look at sport trucks as this is an area where customisation is at it's extreme.
I've got lots more saved up... What are you thinking Darrin?
Wow some of those graphics are pretty insane. That Lamborghini with the graffiti is pretty cool never seen that before. I hate to think what some of those paint jobs cost though. Probably more than the cars in some cases.
Nothing that fancy. Not looking for a autosalon car, will still be a daily driver
I need to paint 80% of my car anyway, so I was thinking a non factory colour.
I have done 7 full colour swaps before on my previous cars. It is a bit more work, but it is worth it.
I like blue's and have considered going bayside blue to stick with the Nissan theme.
Previous cars in blue have been ford cabolt blue on a series 4 RX7, subaru wrx blue on a AW11 MR2 and ford blueprint on my r33.
I am not sure if a darker or lighter colour will suit the bigger car. Might need to check out the new HSV wagons for an idea.
Hmmm I reckon thats a bit too blue Darrin, the Stagea being such a big car I reckon it needs a subtle shade.
I really like dark colours e.g. dark Purple / Plum or Black. Also I have seen some really nice BMW colous lately that I reckon would suit the Stagea Silver Gray Metallic and Sparkling Graphite Metallic the second one looks awesome in the flesh kind of changes colour slightly in the light.
I am thinking maybe a darker colour on the bigger car, something like a dark charcoal metalic
My current R34 gtr bonnet is that dark purple rare nissan colour. Sort of suits the car
I'll be doing a spray job on my car - BUT will keep it Pearl White
want to fix up the mirror areas, a cple of body touchup areas, then pearl white with heaps of purple/electric-blue pearl
just to make it look sparkling, and would be the last final job on the car (prior to bottom end, hehehehe lolz)
heres my r31 wagon with the new look "cherry cola" black with red pearl... should be finished soon its been 5 years in the making... i painted that in the shed and it still needs a buff so go easy on me
  • 5 weeks later...
  • 3 weeks later...
Is this colour too gay?
Lambo orange or ford TX5 electric orange
I need to consider resale as well.
I don't mind it, I spose "some" might claim it's a bit gay but they probably think anything other thank black or white is a bit gay :D
It's a bright orange without being too bright, even a sun burnt orange might be a nice colour choice :blush:
Until you see it on your particular car though it's hard to tell :sick:
WHAT THE HELL!
if your considering resale, forget that colour!
unless you wanna sell it to some sick and twisted person over here in Dandenong who thinks painting there skylines and hondas s200 and even Gti-R in lime green and lambo orange is cool well best of luck to you mate.
quote]
As long as you like attention then go for it, put some 20s on it to like the one in the first pic that thing is cool. Also I don't reckon it will affect resale too much if you look at a whole car for what it is. For exampl I wouldn't pay $100 for a 1600 mitsi lancer with a cheap arse body kit and a candy pink paint job. But a one of a kind stagea / skyline with quality mods throughout good paint and kit is worth paying a bit of money for in my book. Some of the big car makers are thinking this way too look at the ford fpv colours or the Porsche GT3 colour options.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
