I just bought a gfb boost controller for my mostly stock r33, just wondering if anyone could tell me how to install . i have read the manual boost controller install gudies dint realy get it , also is it even a good idea to to turn it up
Dude.................................................C'mon.................................................Really..................
Are you taking the piss or is this for real?
If you aren't then I suggest you find a gearhead in your area who is approachable and ask for help. Maybe a carton of piss in exchange for some knowledge.
It's as easy as the manual says. Cut the wastegate actuator line and insert boost controller. Then set the boost using an aftermarket boost gauge, not the stocker. Don't go beyond 12psi.
If you don't get it yet, ask for help or pay for professional work before you kill the car.
Be careful with the GFB boost controller. They do all the bad stuff. Spike, creep etc. So if u set it to 10 and goes to 13+ your turbo can blow up due to the rear wheel being ceramic. Rather get a ball and spring valve of ebay for like 35$.
aw sheesh, i bought one not long ago! are they THAT bad?
not going into the "Pneumatic" Vs Non Pneumatic needle design but i ran a GFB boost controller for around 8 months with no worries at all. never had spiking issues nor creep.
both will do the job. Just dont mess round with the turbo tech too much and loose the ball bearing.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
