Located in Melbourne (north east Suburbs). Contact Michael on 0419 006 252. Or PM me.
• Wheels - Volk Evolution 4, set of 4, 17 x 7inch, 225/45ZR17, currently fitted to my ER34 (5 stud), has multi stud pattern to fit 4 stud. Offset 35, Tyres 4100kms, lightweight, Excellent condition. $1500.
post-31386-1236604760_thumb.jpg post-31386-1236604775_thumb.jpg post-31386-1236604788_thumb.jpg post-31386-1236604811_thumb.jpg
• JDM Pioneer Carrozzeria head unit with mini disc (flip face with slot concealed), FM/AM. 45w x4 with MOSFET, MEH-P9900. Pioneer Carrozzeria 12 CD stacker CDX-P1250. $100.
Skyline HR31 parts;
• Wheels – set of 4, 3piece, 15x6 inch, 205/60R15 rubber (legal, but not by much), Multi stud pattern, were fitted to my previous HR31, good for anything but a show car. $100 ono
post-31386-1236604986_thumb.jpg post-31386-1236605008_thumb.jpg post-31386-1236605024_thumb.jpg post-31386-1236605039_thumb.jpg
• Engine management – standard, for HR31 – RB20DET, runs a little rich. $40 ono
• Coils x2 – from RB20DET, unknown if working – I’m open to trust here. Pay me if they work after you test them. $25 ono
• Ignition module from HR31 - RB20DET. $50 ono
• R/H front bumper indicator unit, R31. $10 ono
• Fender indicator unit, R31. $10 ono
• RR Wiper, RR wash, hazard button, 2 blank filler buttons. HR31. $10 ono
• HR31 GT trim, L/H fender, grey in colour. $10 ono
Or $200 for the lot of HR31 parts.
https://www.sau.com.au/forums/topic/260399-hr31-parts-and-other-skyline-stuff/
heya still got the cd player and staka?
would you post to sa?
pst code 5255...if you have it still how much for it including postage if u will post,,,thanx
Hi elir32,
PM sent... Yes I can post it to SA.
het mate, what offsets are the 15s?
Hey, I've checked over the wheels, and I just cant find a number for offset. Its a bit frustrating for me. Give me a call.
Oh, and they are actually 6.5 wide, not 6 as mentioned at the top.
$200 for everything from, and including, the 15 inch wheels and down the list!
(excludes the Volks and the Pioneer gear)
Phone Michael on 0419 006 252.
$120 for the lot.
Skyline HR31 parts;
Or $120 for the lot.
UPDATED
  • 2 years later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
