hey can anyone recomend anywhere to take my car for a timing belt replacement. ive got 800km to organise it. i live in ipswich but im willing to drive if i need to.
ive got a series 2 rs4s stagea
thank you in advance
https://www.sau.com.au/forums/topic/260488-timing-belt-replacement/
thanks, i have sent them an email.
is it just me or is there address no where on the internet. i must be going crazy.
As far as i can tell you are not crazy.I couldn't find an address either! I am interested in their location as i need a good workshop.
It is impossible to compare those 2 prices without knowing what is and is not included in each price. We have done plenty of timing belts on RB's and the price varies each time depending on what seals get replaced, the condition of the idler and tensioner bearings, if the water pump is done whilst the front of the engine is apart etc.
Best bet is to make a few calls (including one to us :)) and see what options you have and what back up service you receive. We offer a 100% money back guarantee on all of our servicing work.
I can do it for you, $200 plus parts. Im a qualified mechanic. i have built many RB engines including all of my own.
i highly recommend a gates belt and if your idler and tensioner make any noise at all they need to be replaced.
this is also the time to do the water pump as suggested before. also this is the time to check cam seals and front crank seal in oil pump
as they are easy to do while doing the timming belt is off.
Those thing's are hard to quote when you can come up against unexpected add-on cost I.G. water pump's, defective water hose's ect ect.
Like mercury said, they warrent all work done on vehicle, that's where alot of people go wrong, not knocking old mate who wants to do it for $200, but if something does go wrong, not saying it will, but WHAT IF, will you cover the cost of bent valve's or whatever may happen????????
It pay's to be safe, it pay's to do it by a professional with insurance background.
$400 plus parts is a fair price...considering the timing belt kit including the pulleys, belt etc is $280 makes Dan's quote just about spot on.
I know i wouldn't do it for less than that and if anybody quoting less than that to make a dollar it would have to be a rush job. Remember the cam belt is keeping your valves away from your pistons...a rushed job and error could be very costly.
Edited by DiRTgarage
just because its cheap doesnt mean its a rushed job, and yes if damaged was cause by my mechanical work then i would be liable for those
repairs, it was just an offer, remember i dont have overheads to cover like big workshops.
Im located at the Gold Coast.
We were not saying you do a cheap job, you properly have the same qualification's as most GOOD tech's out there, true about no overheads but doing job's like this can have its rewards and its down fall's if something were to go wrong.
I applause you for having a go thou, i know alot of tech's who wouldnt dare do this kid of work outside work hour, you seem very confidant and good luck.
WHITEY
your time is a valueable thing...i wouldnt charge peanuts to be away from my family or doing things like relaxing with a few coldies around the bbq with friends. If you are good at what you do don't short change yourself...charge accordingly. I dont have a big workshop or any overheads (my mate has a 4 bay shed i work out of and gets free labour on his street/circuit GTR for the favour) either.
this is not mean to be taken as a shot at you...just my opinion and maybe some advice.
i payed just under $1k not to long ago to get my belt, water pump, seals and idlers done. apparently took about 5-6hrs to do the job. to the mechanics reading this, did i pay more than i should have or does this sound resonable.
Nope, has the car had any problem's???
And they properly charged out what the book said it takes to do, that's how you cover your workshop outgoings if something was to go overtime.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
