HKS in/ex camshafts 256 8.7 lift
these are in good condition, have been in car for 20,000kms
they came out of my R33 GTR so im not sure wot other gtr they mite go into
looking for $400 for the pair
would prefer pick up as they are heavy but can arrange postage at buyers expense
HKS 0.7bar adjustable actuators
Also in good condition with 20,000kms use also
these actuators came of a set of HKS 2530's for gtr's
looking for $200 plus postage
Standard r33 GTR exhaust manifolds
items are in good condition
looking for $120 for both plus postage
Standard r33 GTR coil packs
these where still workin fine at 300kw 1.1bar boost, with no sign of ignition breakdown
came out of a 95 GTR
looking for $60 plus postage
Bride Style seats
these came out of my brothers 200sx
have been retrimmed in black suede
items are in excellent condition apart from one tiny split in the side bolster of the drivers seat
this can be easily fixed
seats come with s14 rails
items are around 4 months old but havnt been in the car for about a month now
looking for $400 pick up only
all items are located in Wollongong NSW
if you have any further questions please feel free to pm me
https://www.sau.com.au/forums/topic/260804-gtr-parts/
can you please check how much it would be to send the cams to perth, WA
yeh i can do that, just send me your post code and i can get you an estimate
Actuators sold pending payment
https://www.sau.com.au/forums/topic/260804-gtr-parts/#findComment-4474375
cams sold pending payment
also for sale is a Torque split controller i bought of ebay. item is brand new with everything required for installation including instruction manual. people have had very good experiences with these units
im after $160 which is what i paid for it
Edited by UWISSH!
https://www.sau.com.au/forums/topic/260804-gtr-parts/#findComment-4493716
also up for sale now is a standard r33 GTR v-spec computer with a HKS F-con V ecu wired into it.
this came with my car wen it arrived from japan
the ecu is a piggy back unit that controlls fuel and ignition timming and does not run air flow meters.
comes with all wiring minus the map sensors.
looking for $250 for everything
https://www.sau.com.au/forums/topic/260804-gtr-parts/#findComment-4507218
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
