  • 3 weeks later...
  • 1 month later...
R32 GTR AFM (pair) - $120 + postage
already checked for dry solder - upgraded to nismo item
R32 GTR fuel pump - $80 + postage
great upgrade to RB20 - upgraded to tomei fuel pump
Blitz turbo timer (voice) - $80 + postage
already have apexi turbo timer tied into my alarm
R32 GTR Bov (pair) - $120 + postage
switched to blitz bovs
R32 GTR Projector Headlights (pair) - $120 + postage
one of the headlights has a broken bit at the rear but doesnt affect function
R32 GTR Fuel Pump - $80 + postage (missing sock filter)
R32 GTR/GTS-T 3.15" Catback Exhaust - $400 pickup
does not have a muffler and lightweight
R32/33 GTR PowerFC Pro + Hand Controller - $1350 delivered
brand new in a box
Blitz turbo timer (english and japanese voice) - $80 + postage
R32 GTR/GTS-T 3.15" Catback Exhaust - $350 pickup
brand new in a box
will they work on an r33 rb26dett? and how much 2 get them posted 2 burpengary 4505, qld
yeah sure will, postage would be around $20 odd
  • 3 weeks later...
items still available for sale
Nissan Consult Cable (serial) by PLMS Development - $90 inc postage
afms sold
R32 GTR/GTS-T 3.25" Catback Exhaust - $350 pickup
does not have a mid muffler and very lightweight
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
