i recently sold my car so here are my left over bits n pieces for sale as i no longer have my car!!
all items are in frankston south vic and can be sent at buyers expense...
you can contact me on 0409556340 or pm
Sard 550cc injectors direct swap for rb20!! $1000 new perfect condition $500 firm!
Z32 AFM good condition includes plug $250
Garrett gt3540 turbo (xr6 turbo spec) has a new core and includes exhaust flange and a spare t3 flange and silicon elbow.. mint condition!! $1250 firm!!
Tein Ha coilovers 3 only!! 2 front and one rear! to suit r32 gtr/gts4 the 3 are in good condition no leaks!! $300
brand new rb30 crank collar and 2x 1.5mm oil restrictors.. a must for a rb30 conversion $100
rb20 flywheel.. good condition could do with a machine.. $50
brand New federal 595 tires x2 235/40/18 retail for 300 a Tyre $300 for the pair firm!!
R32 Gtst Rear Slotered Rotors And Bendex Brake Pads.. Brand New $200
Edited by lwboosted
https://www.sau.com.au/forums/topic/260840-performance-parts/
interested in the Teins?
hows the adjusters feel on the them? still stiff?
flexable on the price?
teins are very stiff!! great condition... fairly firm on price... there is only 1 missing and these coilovers retail for almost $2000 new or $1000 second hand!!
injectors sold!!
also i forgot to state the turbo has oil and water fittings,.. so its basically everything u need to bolt on..
Edited by lwboosted
would the coilovers fit a r32 gtst?
also would you seperate and sell just the rear set?
i believe the two front ones will fit its just the rear that are different but i aint 100% sure... the price is bassed on the pair because they are missing one rear.. so its the same price for 2 and you get the 3rd for free.. lol
what pics do u want me to take?? they are brand new in the box... they look like brand new slotted rotors???
Edited by lwboosted
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
