Hey fellas.
Looking into brake upgrades for my R31, and I have read and heard lots of conflicting information.
Over at the R31 Skyline Club, we have this table:
My original plan was to use a early R32 GTS-t caliper with the later R33 GTS rotor. As far as I'm aware, this is not a problem.
The reason I would prefer to use the R33 GTS rotor is because it is 4-stud as standard, which means no re-drilling, which means it's engineerable. I'm trying to keep as legal as possible, I want my car engineered as it's going to be my daily.
Now, I have heard that the early R32 GTS-t calipers which suit the 280mm rotor aren't 4-pot? Is this correct?
I was under the impression all R32 GTS-t calipers were 4-pot.
Any help would be greatly appriciated.
Cheers.
https://www.sau.com.au/forums/topic/260870-brake-upgrades/
hey mate
with my limited brake knowledge all i know is that the R32 GTS-t Type M calipers are 4 - pots, where all the other ones are not.
and The type Ms are the late model R32's - so 89, 90, maybe even 91 modles are only 2 pots.
I am not 100% on this - the only thing i am 100% on is that only Type M's are 4 pot calipers.
hope this helps you in some way
cheers :/
https://www.sau.com.au/forums/topic/260870-brake-upgrades/#findComment-4474609
My 1990 Type M brakes were 4-pot.
What about changing hubs? not sure how they do it but the silvia boys and na skyline boys do a 5-stud conversion.. might want to look into that and run the 296mm rotor/33gtst caliper setup.
https://www.sau.com.au/forums/topic/260870-brake-upgrades/#findComment-4475335
I have thought using 5-stud hubs up front, but I would prefer to keep the car using 1 stud pattern, and not really keen on getting new 5-stud axles made up.
The main question I would like to know is whether early R32 GTS-t's which used the 280x26 rotor are 2-pot or 4-pot.
If they're 2-pot I'll just look for some R33 GTS calipers.
https://www.sau.com.au/forums/topic/260870-brake-upgrades/#findComment-4476262
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
