hello all, now i admit i am new to cars and turbos and stuff and probably dont know wat im on about, but i havea hks ssbov and everywhere i go people seem to be bad mouthing it becuase it apparently makes ur car stall and shit like that.
now i went through those problems as well, but i later found that wen having a hks ssbov u are also required to have a hks idle stabaliser, and wen i got that in, everything worked like a charm!!!!!!!!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/26090-hks-ssbov/
Flutter is not from the BOV it is from the air flowing back through the turbo. It's not good for the turbo at all. Obviously by over-tightening the BOV you're gonna end up with the air going thru the turbo as it can't vent, hence the flutter.
https://www.sau.com.au/forums/topic/26090-hks-ssbov/#findComment-553759
One of the things about Jap BOV's is that unlike ones from Oz they aren't all simply products of the metal laythe....A lot of Jap ones are actually cast items, this is why they are far more expensive. From memory the HKS Sequencial BOV is not adjustable, I had one a long time ago on my starlet. The Super Sequencial is though.....then of course there is the Super Racing BOV from HKS, now that's expensive :)
https://www.sau.com.au/forums/topic/26090-hks-ssbov/#findComment-553810
As I said I don't think you can adjust the older one. If yours has adjustment then what it does is put more pre-load on the actualto spring insied the bov and makes it hard to force open, you do this if you run higher boost (set it soft for low boost cars and hard for cars with much higher boost) The basic rule of thumb is set it hard so you hear the flutter then back it off till you can't here it any more ..... that should be the right setting.
https://www.sau.com.au/forums/topic/26090-hks-ssbov/#findComment-554179
because the SSQV as 2 valves, the smaller purple pointy thingy and the bigger valve with the HKS wordings...the screw only adjusts the tightness of the big valve.
i've yet to solve the damn fluttering problem because of this...no matter how loose i turn it.....it only affects the bigger valve...
https://www.sau.com.au/forums/topic/26090-hks-ssbov/#findComment-554679
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
