Hey guys, sorry if this has been covered somewhere - I have done quite a bit of trawling and there is HEAPS of information on building RB30DETs and even information on squeezing the RB30 into an R32 in such a way as to not get clearance issues but I've not found anything specific on the R33 (which obviously has a different engine bay and factory deck height), and I figure there are bound to have been people who have tried here so someone should be able to provide an easy yes/no answer and I am sure someone else would do the same search.
Are there any clearance issues when putting an RB30 bottom end under the stock RB25 head in an R33 GTS25t when retaining the stock plenum/cross over pipe, are there any basic mods to make it work, or is getting a forward facing plenum imperative to making it work?
I quite like my turbo setup etc, the stock plenum and exhaust manifold are definitely capable of making the power I want... I am more looking at the 3litre for reliability (addressing oil control and having a fresh engine as well as the fact the 30s are tough) as well as the obvious huge boost in power delivery of having a 3litre are the big motivators for looking into this as the car is primarily daily driver vs drag/track. The added cost of having to change manifolds, piping etc would sway my decision on whether I'd go RB30 or not.
Cheers,
Lith0r.
PS, I just realised/remembered there is an RB30DET area and this probably should be in there but can't move the post myself ;)
Edited by Lithium
yes there are clearance issues. Yes i have had to change stuff to mine to make it fit with the stock plenum.
No i wont tell you if you cannot search, paypal me $100 and i will give you the information.
Bet that search button is looking like a better option now ?
OK my apologies, I could swear I had read the RB30DET guide and that it talked about space in an R32 GTSt - not an R33. I had another read and it answers my questions perfectly. Maybe I did something blonde like interpreted a useage of "GTST" somewhere as meaning an R32, over here R33 "GTSt"s tend to be referred to as "25T"s. Either way my bad.
Cheers for the help guys
Search works quite well then :banana:
I will PM the mods and tell them its working again
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
