Seeing as this has become a popular topic again, i'd strong suggest going for a "Mobility" hard-drive, that is, one that is designed for falls - basically a laptop HD.
OR, go with a nice new SSD - the speed is great, and they are shock safe. (little bit pricier though)
I have just ordered the parts for my new carputer. The old PC I was going to canibalise didn't work out, so ended up needing to start from scratch. I ended up getting a 32GB Disk On Module (basically an SDD, never tried them so I'll see) for just under $100 delivered, from eBay. There were cheaper ones, but the sellers had less history. I also think I could of goine for something as small as 4GB (read cheaper again), but would of hated to have to go back for a second purchase.
32GB should do you fine for an OS and basic applications, i have LOTS of media, so i have a terrabyte HD in there - but the SDD will help you greatly.
Good luck - let me know if you get stuck!
see, this is where I know the 32GB is way over . Its simply for the system disk.:whistling: I plan on using a 64+GB (possibly muiltiple, or even a 125GB) USB stick(s) for my media storrage, with a cabin USB port for new and transfer of stuff. The PC I think has 4-6 USB ports on the board (it hasnt arrived yet). I also have a lot of media. Actually, just reading over this, your right, I could use the 32GB disk for a cut down copy of my media library.
I do however plan / hope to use the PC for other software (car related) such as OBDII display (on the OEM screen), navigation (currently use my mobile and can "Remote desktop" onto it from the PC to show on OEM screen)
I have a bad habbit of just upsizing. I estimated I would need around 2-4GB for XP and a front-end (at this stage XBMC is the front runner), and on my PC, I went for all memory slots filled, to give me 2GB.
So far its cost me:
$15 Motherboard (2.4GH P4)
$60 Memory (2GB)
$15 postage
$100 12v power unit for PC
$80 32GB DOM (ie SATA SDD)
Plus the AV plug from Chriss
I still need to get the case (I am thinking something like a big tuppaware box...
The cabling (should only be a few wires and fuses). Any USB cables will be the biggest expense here.
I also plan on getting a 240v to 12v transformer so I can build it and run at home before I install it ($90 from DSE)
In the first instance, I am looking at a small cordless keyboard with a touchpad mouse I saw the other day (I think 15cm x 7cm with QWERTY keyboard), I think it was either $50 or $80. In the future I will probably fit a USB touch screen overlay over the OEM screen.
Once I get it all up and running, I will probably get Chris's contact in Sydney, to put all the wires behind panels and under carpets etc
you could probably get away with an old regular computer power supply (assuming the 12V line has sufficient amperage..) - certainly what I use for bench testing my carpc .. (you just need to short a coupla pins together in the ATX plug to kick it on - google for which ones)
If anyone wants to give me a heads up for any problems they have encountered, feel free! please? The big questions in my head right now is the wiring of the DC-DC PSU (with all the start-up and shut-down specific wires, and wiring that to my motherboard & car :unsure: ) anyone?
The motherboard arrived last week (with 2.4GHz hyper-threaded CPU & 4GB of memory). Hopefully the disk will arrive this week, and I will source the power supply as well. I forgot to mention in the last big post, I will also be getting a new video board that has an S-Video out in NTSC ($50-$80 new). I already have an S-Video to RCA plug from my current home PC that I do not use.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
