up for sale i have,
set of 6 440cc r34 gtr injectors which have been cleaned at flow tested at "injection correction" in hornsby approx 3 months ago and since then have not been fitted and are still in packaging.
good for rb20 or rb26 for a little over 300rwkw
cost me $300 to buy injectors
$170 to clean and flow injectors flowed at 440cc
only asking $300+delivery but prefer pick up in sydney. reason for selling is that i bought a r34 and sold the r32.
also for sale is a front bar off a r32 skyline plus a side skirt for passenger and rear pods for rear bottom quarters.
front bar has been modified to accept front mount intercooler and side skirt has a crack in it.
otherwise could do with paint if your real picky...rear pods are in good condition.
pick up only in sydney.
side pods $50
side skirt $20
front bar $50
or all of them for $100.
also for sale rb20det turbo from r32 93 model 80,000k's never boosted other then standard in immaculate condition without a spot of blowby or bearing movement with inlet flange, water lines, oil bolt, oil dump.
$180+postage or pick up preffered.
r34 gtr fuel pump with fuel sensor etc
came off gtr with 30,000k's in great condition good for little over 300rwkw
$100+postage or pick up preffered
also r32 gtst factory alloy wheels 16" with 90-95% tread only has minor gutter rash on "one" wheel barely noticable came off 80,000k car in top condition in as new "intenza sava" 225/50/16 tyres cost me $150 each.
tyres alone cost me $600
price: $350 for wheels and tryes, pick up only sydney
rb20det standard air filter box
great condition with brand new air filter panel..just needs external metal clips which you can source for a buck or two from a wreckers.
price:$25.00 ono
rb25,rb20det head covers a bit greasy but nothing degreaser couldnt clean up as new...
$50 pick up only.
prices are cheap as they are so no low ballers all parts are genuine and as described so 1st in with money best in.
"parts will be on ebay in a week if not picked up on here"
parts located in sydneys west
contact me via pm or on 0424266986
happy shopping.
side skirts and pods for 2door or 4 door
from what im aware pods can be used on either 2 or 4 door.
but either way these are from a 2 door.
hi mate
thinking of geting your turbo but what else do i have to do? extra work like tuning any ideas? cause my car has got a boost gauge of i think 10 psi
the turbo is still for sale, i know its in great condition and will take 10 psi without any issues.
pm me if interested.
up for sale i have,
side pods $50
side skirt $20
front bar $50
price:$25.00 ono
$50 pick up only.
happy shopping.
actually my number is 0424266984
injectors sold, pods sold (pending payment), fuel pump sold, wheels sold, turbo sold, cam covers sold.
still for sale, $25 front bar, $15 passenger side skirt, $20 standard r32 air filter box with air filter. all items pick up only
from syd, 2197.
  • 5 weeks later...
from syd, 2197.
only these items left...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
