Ok I've searched the forums to get some info in installing a boost controller and now know to make sure that the correct side of the manual boost controller is mated to the wastgate actuator and the other side to the turbo compressor housing.
My question is:
In a r33 gts-t which side of the hose (once both sides are removed from solenoid) is the wastgate actuator side? I'm not sure if it is the side closest to the firewall or the side closest to the front of the car. By "side" I mean when standing on the passenger side of the engine bay looking down at the solenoid, one side of the hose is connected to the cabin side and the other to the front side of the solenoid. I don't know which side is what.
Also, once I disconnect these hoses from the actuator, I am going to have a left over hose from the solenoid... what do I do with it? Plug it?
thanks in advance.
https://www.sau.com.au/forums/topic/26111-boost-controller-questions/
I'd like to help but I'm not really knowledgable of the whole boost control setup. My car came with an electronic boost controller, and one vacuum line from it goes to the actuator. I haven't looked thoroughly enough to see where the other lines go. Your description of the actuator sounds right, if that's of any help. Sorry I couldn't help any more!
is the boost solenoid that metal thing that is near the strut tower and air box? Whatever that thing is I have taken the two rubber hoses off the top of it (one goes to actuator the other goes into the turbo) and placed the bleed valve in between the two. The valve is a DNA Motorsport valve and it doesn't seem to be boosting more than standard (about 8psi) so I'm not sure if that was the correct hose... It's too hard for me to test boost now anywayz so I might leave it till tomorrow. The neighbours have the shits, its raining and dark and all i get is sideways everytime I put my foot down :)
Hey lads,
Remove the turbo heat shield and this appears a little simpler. There is a hose that runs from the soleniod to the wastegate actuator (brass hat-thing) - the actuator is easy to identify because it has a metal arm that physically moves and opens the bypass on the exhaust side of your turbo.
When installing a bleed valve, simply cut this pipe and insert your valve. Be careful when upping your boost, these bleed valves have been known to produce boost spikes and increase a few psi boost with minimal turning of the knob.
Oh yeah, and you don't have to remove/cut any other pipes or lines for the install (unless you are installing an electronic boost controller, in which case you are supplied with a different solenoid and pressure sensor).
Hope it helps,
I was told not to cut any hoses?
If you cut the hose you won't be bypassing the factory solenoid in which case you will get your boost increase after 5000rpm. From what I've heard u don't need to cut the hose but simply "unplug" the hose from both sides of the solenoid and add in ur bleed valve.
Does anyone have a pic of their bleed valve installed? It would help heaps as I plan on tuning the boost tomorrow.
If you go to the Turbosmart website, it has installation instructions for the "Gated" Boost Controller and it has a pic of the Turbo by itself with arrows pointing to what's what.
http://www.turbosmart.com.au/pdf/FG-GBCV-BT.PDF
ok all done.
For those that are going to do this here are some tips:
The hose that you need is the one that goes from the actuator (a goldish coloured hat-shaped thing in front of the turbo) to the intercooler piping up near the airbox. You will notice a T-Piece in this hose, that t-piece goes into the boost solenoid. Start by pulling the t-piece out. In it's place put your bleed valve, remember to plug the side of your bleed valve that is supposed to be attached to the actuator line into the side of the hose closest to the actuator. With the extra hose that comes off the solenoid, I simply put a screw in it to keep it blocked.
And that's it! Should take about 10-20 mins. It really is a simple job once you find out which hose to use :P
  • 2 months later...
Thx GTR R32
http://www.greddy.com/Technical/profec_frame.htm
Im assuming the intake manifold hose is the one that leads from the plenum to the BOV?
so just use a T-fitting and connect this to the controller?
Not sure about the wastegate actuator connection though. Am I suppose to disconnect the hose that leads to the solenoid and replace it with a hose to the stepper motor?
  • 2 months later...
ok all done.
And that's it! Should take about 10-20 mins. It really is a simple job once you find out which hose to use :D
Thanks for the quick rundown fireblade. I installed mine today with minimum fuss. I was very surprised at how easy it was once I worked out what was what. I now have my boost dialed up to 0.8 bar and it's rockin. The boost response seems much smoother across the rev range now too.
Next step is to add my new Air/Fuel ratio metre so that I can intelligently use my S-AFC(Gen 1).
Thanks again.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
