why did you start another thread asking the same question?
^^ x2
If you haven't tried everything in that thread - which I'm sure you haven't why are you posting again?
You have obviously damaged something and your not up to the task of finding out what it is... It's not like is going to be a plug that isnt in all the way or something! You drove through water, you said it was bonnet height... this is not good especially when the car is trying to suck it in!!!
Bad news about the car, however, don't just post up another thread and talk about it some more - GO TO A MECHANIC and stop asking what it could be.
We can keep guessing all day though if you like...
are you really expecting a better answer than this? (from your last thread)
he's gone to much effort to explain it to you.
go get it looked at, or try the stuff thats been recommended
if theres water in your engine............
then thats the first sign ..and the culprit to many issues that can derive from that.
you think about it....at the bottom of the sump the Oil pick up /strainer will suck oil via the pump...
pump it through and under the cylinders...... the piston rings restrain most of the oil getting into the combustion......(but older engines with worn piston rings can let oil in..thats why you see the black smoke)
water is so much more fine than engine oil.....it will make it past the piston rings for sure... hence causing pinging/knocking etc.
at this point.....its hard to say....especially not being able to see the car...
but i feel that you haven't bent anything or f**ked any bearings yet........
because you haven't run it with water in the engine for extensive periods of time...
or have you?
cause from what you explained......you didn't say whether you drove it after or not..
if you did...then there is a possibility piston rings would be the first to go as well as other things...
so like i said, get engine flush....put it in...run it for a min........drain the oil
put new oil and check your spark plugs one more time.
this way you eliminate another possible culprit......
its all about diagnostics.....
Edited by Munkyb0y
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
