Congrats Rob and Co! You must be rapt :blink:
He ran 4 7s at a meet today at Meremere NZ, all at around 176mph and the fastest of which a 7.89 @ 176mph (basically in limiter in top gear) after tuning the car for a bit more boost this week. Still running the Nissan crankshaft!
What is the fastest RB30 powered drag car anyone knows of?
https://www.sau.com.au/forums/topic/261181-rips-240z-into-the-7s/
And what is the minimum for the next class you're looking at?
Is there any point selling the zed? Since you've come so far wth it, if all it needs is new ratios and a trip to weight watchers - wouldnt you want to see just how far the little datto can be pushed? :P
600kg minimum for the next class we'll have the motor in (but it'll probably be around 750kg all up) and then 765kg minimum for the class we intend to run after that or if we go back to Pro Import 1060kg.
Is there any point selling the zed? Since you've come so far wth it, if all it needs is new ratios and a trip to weight watchers - wouldnt you want to see just how far the little datto can be pushed? :thumbsup:
The 240z is a street car (missing headlights, wipers and a muffler, it has a 6 point street cage, glass, full dash etc, its short, it has a high COG and it has done more than I ever thought it could do, its time to get the motor into something purpose built.
Rob
What the hell is in the r32 at the 4min 18sec mark?
Another RIPS RB30'd car?
Nah, it belongs to Joe Kyle (aka Yoda) - a lad who runs his own shop in West Auckland and been around with that car for ages. If I remember rightly it runs a fully built stock displacement RB26DET with a T51R SPL on pump gas and full normal street tyres, he's not a forum goer to my knowledge or anything but its a very very tough streeter.
Edited by Lithium
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
