Congrats Rob and Co! You must be rapt :blink:
He ran 4 7s at a meet today at Meremere NZ, all at around 176mph and the fastest of which a 7.89 @ 176mph (basically in limiter in top gear) after tuning the car for a bit more boost this week. Still running the Nissan crankshaft!
What is the fastest RB30 powered drag car anyone knows of?
https://www.sau.com.au/forums/topic/261181-rips-240z-into-the-7s/
And what is the minimum for the next class you're looking at?
Is there any point selling the zed? Since you've come so far wth it, if all it needs is new ratios and a trip to weight watchers - wouldnt you want to see just how far the little datto can be pushed? :P
600kg minimum for the next class we'll have the motor in (but it'll probably be around 750kg all up) and then 765kg minimum for the class we intend to run after that or if we go back to Pro Import 1060kg.
Is there any point selling the zed? Since you've come so far wth it, if all it needs is new ratios and a trip to weight watchers - wouldnt you want to see just how far the little datto can be pushed? :thumbsup:
The 240z is a street car (missing headlights, wipers and a muffler, it has a 6 point street cage, glass, full dash etc, its short, it has a high COG and it has done more than I ever thought it could do, its time to get the motor into something purpose built.
Rob
What the hell is in the r32 at the 4min 18sec mark?
Another RIPS RB30'd car?
Nah, it belongs to Joe Kyle (aka Yoda) - a lad who runs his own shop in West Auckland and been around with that car for ages. If I remember rightly it runs a fully built stock displacement RB26DET with a T51R SPL on pump gas and full normal street tyres, he's not a forum goer to my knowledge or anything but its a very very tough streeter.
Edited by Lithium
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
