i live in kenmore, could be keen, although, i probs cant be out for long hey, i have 2 tests the next day lol, and some1 has to put up their hand to get pulled over b4 me because they like to ass rape my car :ph34r:
most people round my area would defently have seen me as my car sticks out like dogs balls
JV
I see a yellow R34 GTt parked on High St everyday I go to work. Wonder who that is.
He works in one of the offices on the train track side of High St.. I walk past it most days trudgin up to work... haven't seen anything SAU related on it anywhere... might have to leave him a card before I get moved back to the city at the end of the week.
spose The Gap is prob just too far away from dem der subs, usda work in Milton Cribb St
I'm just on the Nebo side and hear and see all kindsa things drivin up to the hills, also see few tow trucks and ambos headin there too, not good though!
haha gold love that photooo
yo sly32 we spotted you today - we were in the black cefie and the gunmetal 32 on moggill - we were trying to invite you to hjs...
then you dogged at the lights :blink:
Always can,
Cannot promise I will be sane most of the time..
supposedly i have a dry humor problem :S
Nismo boy where is jooor office!?..
i might make astrotristian rip a sik skid in his undies for u!
haha lol
Edited by Redsuns88
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
