do you guys wanna go see star trek at the movies instead? I've watched wolverine already so meh.
I'm at Kelvin Grove but I do work a fair bit around the Toowong area.. I have a blue 34, has nsw numberplates because I like to keep it mixed up :starwars:
If I pass another skyline I always give it a wave but 4/5 times they'll just give me a dirty look back :blush:
Chances are I've probably seen some of you around anyway... keen to meet up for dinner/beers/whatnot if it happens ;)
I'm at Kelvin Grove but I do work a fair bit around the Toowong area.. I have a blue 34, has nsw numberplates because I like to keep it mixed up :D
If I pass another skyline I always give it a wave but 4/5 times they'll just give me a dirty look back :(
Chances are I've probably seen some of you around anyway... keen to meet up for dinner/beers/whatnot if it happens :)
hey matey,
im almost in your position - i used to live on that side of town - but now im at wilston, just around the corner from kg!
next time we shud catch up first n cruise over to the otherss
Pretty... all its got when I bought it is a Trust Ti-R exhaust system and the small 18" Works Emo rims...
I'm thinking of downgrading the exhaust to something softer/legal and not have much effect on power. The others would be to get a new ecu, probably De-Jetro with Apexi PFC Boost Controller. And the most exp 1 would be to change those rims to 18" or 19" Volks TE37 or LMGT4 with proper offsets/width (current they're on 235 tyres!!!). And hopefully with these and a tune it'll gimme a safe 300kW.
Edited by Brandon
Yeah for sure mate,
I just need to put the engine back in haha... I got bored and ripped out out on the weekend to do some cleaning, never ripped an engine out of a GTR before, didn't realise how much was involved so I got over putting it back in pretty quickly, resorted to driving the GF's car for the week :D
When is the next meet going to be on out of curiosity?
hey matey,
i see i see, imo dont butcher a v-spec r33 if its pretty stock, by going crazy with mods, that sounds good though - cant wait to check it out
in regards to the next meet not too sure hey, probs next thursday..
are you going to do anything to the motor now that its out? or just clean it?
you have too much spare time on your hands mate,
now that its out though - ill swap ya for my rb20 :D
Yea I wouldnt do anything more that that list. It just feels really laggy/sluggish now.
Anyway its just a shame that the time is always not right. Hope I'll make it the next time.
Nice mod list made.. if i was you should have a chat with PCE Performance Im sure they can work out a wicked deal for you with the ECU and other performance mods.
as for the meet most of us will be at the drift event watching astro and 32 dave. let me us know if u want to come along..i will be there when the gates open..
cheers.
Dunno if I'll make it out to QR tonight. Just got into work trying to convert my uni assignment to the right format so I can print it n bind it and the motherf**ker wont work. Might have to go home to get the original file and print it off at uni. I f**kin hate uni assignments. :verymad:
cheers.
Where and what time is it? I'll see if I can make it.
Spotted green 33SUM this morning on the motorway to work this morning.
I enjoy giving boys between the ages of 5 and 10 phantom hands, and regularly do so in suburbs on the inner south.
In short, I am a dirty dirty man, and should be reported to the authorities ASAP.
TBF you would fit right in with this group. The amount of phantom handing that goes on is unbelievable.
Oh boo ya got my uni shit sorted so I'm on for QR tonight. FTMFW
And status on my wheels is
07/05/0917:13:08SydneyYour parcel is currently in transit between our Sydney and Gold Coast depots.
They need to stop draggin their feet...
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
