Ever flat changed a car with 500rwhp :P
BANG!! haha.
er no im not a retard..
Might do Nado's. Duno, should be there for BnR.
Might miss the car wash though
think ur a mad dog - skip nandos, skid car wash, change gears without a clutch
You'd think a gearset could handle it though :P
Skids you say. *rubs chin*
smity u coming thursday?
i kno you are geoff
Yep, you got me. I'll be there for nando's and B&R.
Not too sure if I'll make it to the car wash even though mine does look like its been rolling in mud and bird shit.
Slacker josh come wash your pig n do some skids. Show the vtec boys how it's done :happy:
Nah I gotta put my other sunroof rails in, as the one thats in the car is f**ked. so no water sports atm
500rwhp? Is that from all your epic weight reduction... Nismo_Boy = Mong stick basher, Cant wait to see this 32. Shim your diff up yourself, arvo's work mate :happy: Smithy, unfortunate about the head drama. Cant wait to see cols, XD9's up in person For all those who thought where did Dave go... Since 56k isn't worth doing anything on, this is what I've been doing. She's coming along nicely. Like my Diy coilpack loom... haha gotta wrap it yet tho.
Turbo will be checked this week, if it required rebuild... mmm highflowzzzzzzzz
T78 among other things...
I dont have tools, let alone a jack..
PCE Performance does give them a burl..
rofl great night tonight guys rofl..
poor tristian love you long time mang..
newmarket maccers = emos + misfits plus randoms
Edited by Redsuns88
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
