dave, when you get the parcel shelf, don't unpick it in the car, please for the love of god, cut around it so that the weld of the parcel shelf are still intact... then take your time to unpick it. last time you unpicked welds while it was on your car you seriously munted it.
i got the right drill bit now :( its a minute hole saw, cuts the spot out of the metal :) last time i was just using a drill bit and a screw driver. lol parcel trays in a wreck at cameron's body works, so i have to unpick it at there shop, doing that on saturday. and should be easy to weld in :)
18x10.25 on the front and 18x10.5 on the rear.
At some stage i'll put the rear outter bands on the fronts, and order new rear bands to make them an 11.5
Not happy with the stance yet. just running 225's all round, but might roll 215's with spacers until I swap outter rim bands. Atm has no spacers.
no i think dave re hosted it!
lol snap
brandon - im keen for a little chill, but i need to be picked up and dropped off
no way n f**king riding my bike down the m1
wud make an epic photo however
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
