dave, when you get the parcel shelf, don't unpick it in the car, please for the love of god, cut around it so that the weld of the parcel shelf are still intact... then take your time to unpick it. last time you unpicked welds while it was on your car you seriously munted it.
i got the right drill bit now :( its a minute hole saw, cuts the spot out of the metal :) last time i was just using a drill bit and a screw driver. lol parcel trays in a wreck at cameron's body works, so i have to unpick it at there shop, doing that on saturday. and should be easy to weld in :)
18x10.25 on the front and 18x10.5 on the rear.
At some stage i'll put the rear outter bands on the fronts, and order new rear bands to make them an 11.5
Not happy with the stance yet. just running 225's all round, but might roll 215's with spacers until I swap outter rim bands. Atm has no spacers.
no i think dave re hosted it!
lol snap
brandon - im keen for a little chill, but i need to be picked up and dropped off
no way n f**king riding my bike down the m1
wud make an epic photo however
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
